My heads are set up for PAC 1396 valve springs with 1.950 installed height. Here is PACs description:
Circle Track 1300 Series Valve Spring High Lift Roller Spring - damperless
Outside Diameter 1.574
Outer Spring ID 1.15
Inner Spring ID 0.826
Install Height 2
Load at Installed Height 260
Spring Open Height 1.2
Spring Open Load 690
Recommended Valve Lift 0.8
Spring Rate (lbs/in) 538
Coil Bind (max) 1.15
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
