I bought a caliper rebuild kit that included new pistons, O rings, dust seals and caliper slide pins. I didn’t bother to put the anti rattle clips on. The bores looked really good with no pitting.
It’s a 70k mile car and the caliper mounting brackets and any other wear points look good.
When I rebuilt the calipers the pistons seemed to slide into the bores easy enough.
It is a one piece proportioning valve that is not available new.
I had planned on doing a manual bleed in the morning, but now it may be next weekend. I may need to simply replace the DS caliper and see what happens.
Thx
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
