"Metal spalling is a process of metallic surface failure in which the metal is broken down into small flakes (spalls) from a larger solid body. This process occurs for many reasons, such as when another material impacts it at a high speed resulting in chipping the material, or due to corrosion, weathering, cavitation or excessive rolling pressure."
The INTERNET, the MISinformation superhighway
