It can cause some bumpsteer problems, measure the toe at ride height & then lift front up to just touching the bump stops & remeasure the toe, .5 toe change is not great but is tolerable, I set the toe with front up like making a pass.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
