I've mounted electric pumps in different locations depending on the car and its purpose: Rear body crossmember on the drag car, R/R frame rail forward of the tire on a couple, on the rear shock crossmember on another couple. One of the shock-crossmember cars was my Hemi RR. That pump lasted forever there & worked. It's true that they push better than suck, but never had a problem.
