Originally Posted by Sniper
Originally Posted by MrBuffo
I see this is an old post but I was wondering if you did have pistons made for the 413-1 ? I have mine torn apart now trying to track down some engine noise , I'm thinking about putting a new cam in it . Not sure if I can find a replacement close to stock, I gotta make some calls I guess, any camshaft in mind that would fit this motor?Anyway, Thanks for any input
Not sure how you thought reviving a dead 10 year old thread that was mostly a pissing contest was gonna help, a fresh thread would have done better, mostly because old Doc flappergasser will fire back up and this thread will turn too poo again.
That said any custom piston maker will make whatever piston you want. Or you could have looked at Summit Racing and see what they had.
Back when I redid the 413 in my 64 300 I ran the old DC Street Hemi grind in it. Basically it had the same specs as the Hemi but n a B/RB cam, P4452993AE is the latest version.
Hay Snoopy .... that’s Duck FlipperMaster !
Reasonable replacement pistons are still available out there
