Originally Posted by Frank Cannon
Originally Posted by TRENDZ
...with a splash of nitromethane? Yes.
No.
Quote
E. Fuel
Any use of M3, M5, nitro-methane, polypropylene, and/or hydrazine are prohibited. Gasoline as defined by a mixture of hydrocarbons is permitted. The use of methanol fuel is for naturally-aspirated, turbocharged, and supercharged engine combinations. Methanol must be pure U.S. federal grades A or AA without the addition of additives, masking agents or any other substances. NPK Tech Dept reserves the right to check fuel at any time. Failure to pass fuel check is grounds for disallowance of the run and disqualification from the event during eliminations.
https://www.noprep.com/2019-no-prep-kings-rules-as-of-12-3-2018/
That is only if he runs no prep.
Other times, he mixes some nitro.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
