You could do that with a residual pressure valve which you would need anyway as the line will bleed the fluid back down to the master, damn gravity. I'm not sure how well a residual valve will perform on a hydraulic clutch though. The best way to fix this would be to reroute the line. Maybe you could use a mix of flex and hard line to get the routing you need in tight areas.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
