That much temp gain in that short time says your radiator is WAY TOO SMALL and your water pump doesn't flow enough. You have enough airflow moving down the track that the fan isn't a factor.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
