i like the MSD crimpers as well, but i have 6 or 8 others i use depending on the circumstances. the ones that come with the eleventybillion piece connector kit from elcheapistan need to go directly to the trash can. in fact, just don't buy that kit to start with !
i also use marine grade heat shrink. it has the glue inside that makes the connection moisture proof.
beer
