A couple of minor things... Decided the heads are going back up to Dwayne's after I started having cold sweats over the possibility of somebody else doing a sub-par job.
Also, didn't like the raw fuel trail that was showing in the bowls behind the valve guides, so I went over the bowls & runner surfaces (but
not the short turns) and put a bit o' texture on them to help w/ fuel fallout issues. Or so the theory goes...
Bowl pic is "before" w/ the fuel trail highlighted; runner pic shows surface texture applied.
