The original issue still exists, that with both points in use, the engine stumbles just above idle, to the point that it is not even drivable. As I mentioned, if I isolate EITHER set of points, it runs normally.
I would question the integrity of your coil as blocking either set points changes the dwell and has a direct effect on the coils saturation time That appears to be the only variable IMO
