Need to get a hold of a dwell meter, better yet find someone with a good old fashioned sun distributor machine and set that up correctly. I've seen brand new distributors loose their mind at 1k and above. Also a machime will let you fine tune the vacuum and centrifugal advance. I used to teach auto shop and i would let guys come in and use mine so check there.
