Quote
Next I think I will try a 180 stat and antifreeze.
I would hold off on that tho winter is coming & temp does need to be above 180 & what Sniper said, there is an airflow problem (assuming the rad flows well). EDIT on second thought if the rd was partly plugged it would run hot a speed (more eng heat/not enough flow to cool)
