Originally Posted by NITROUSN
Originally Posted by topside
Imperial Services may make throttle cables.
Or try the Slant 6 cable, that's supposed to be quite long.
Failing that, it's either an adapter bracket or moving the attachment point lower on the throttle arm.
Is imperial services still in business?
Slant six has a longer stroke?
I already am lower on the throttle arm.
No adapter will help.
I dont understand why your car is different than all these other cars, is your accelerator pedal bent cracked ? something else going on here,
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
