A 440-2 is probably the best choice for you. The Indy dual plane would also work but I think the 440-2 is a better option. The Indy intakes that I've seen lately don't look very good coming out of the box so you will most likely need to do some port match work. If you're not set up for that then buy the intake from Hughes and have them do their deep port match. That way when you open the box it will bolt on and be ready to go.
