Remove your distributor cap so you can see the rotor.
Get a breaker bar & find a socket the right size for the harmonic balancer bolt inside the crank pulley.
Rotate engine just until you see the rotor end move.
Then change directions, if you can turn the engine several degrees before the rotor starts to swing back, your timing chain and / or pulleys have worn to excess.
