Originally Posted by cdwmotorsports
The fans only cycle when the Dakota Digital box and the sending unit agree they need to come one, then it has the option of running itself on low or high as needed. The car is wired correctly. The alternator has one of Crackedback Rob's big wires from it. The alternator doesn't appear to be outputting more than 11.4 volts into the system.
You either have a bad alternator or it isn't wired correctly. Shouldn't be too hard to figure out either way. Take it to your local NAPA and they'll tell you if it is working. If it works on the NAPA test bench then you have the car wired wrong.
