Did you see what the real problem is? Improper angle on the rear shackles. It helps to read more than just the op when replying because sometimes that leads to wrong advice.
OK, I get it. But I read each post (again), the word "angle" never said.
Low, Lower, Height, mentioned in nearly every post. Last thing I would want to do is give bad advice, because I come here a lot looking for advice, and normally get good advice. I receive a lot more from this site than I give.
The main thing is that he is able to get the "good" advice that will allow him to resolve his issue, angle or height.
