At speed, a pusher fan serves mostly to block airflow through a radiator.
But yeah, by definition siamese bores don't allow a full-perimeter water jacket, so your existing system is cooling a hotter block.
FWIW, water is better at cooling than anti-freeze is, so if the thing never sees freezing temps, you can reduce the % of anti-freeze.
10%-25% cools better.
