Originally Posted by Diplomat360
Originally Posted by krautrock
you need to look at the shape of the lobe and without getting too deep into it, look at duartion @ .050 and also @.200, you have to find a lobe profile catalog usually.
here is an example from Howards.
https://www.howardscams.com/sites/default/files/lobe%20list%20email%201-20-2014.pdf...
YES, perfect!
This is exactly the sort of information I'm curious about, especially the theory behind things like the nose duration, etc.
So given that I picked up a custom ground CompCams hydraulic roller (thus my focus on the CompCams parts, not meaning to ignore the other guys) I actually reached out to their tech folks and asked for the grind card, which they shared. The cam has the 13084 & 3039 lobes, these are the Xtreme Energy XFI rollers:
Lobe 13084:
.006 dur is 290
.050 dur is 240
.200 dur is 163
Lobe 3039:
.006 dur is 300
.050 dur is 248
.200 dur is 169
Now, if I had that same info available for the other grinds I would have happily posted those as well, alas, I do not.
A hydraulic roller (or a solid roller) is a bit different. But lifter diameter still matters, maybe even more so with a roller. With a lifter bore of .842 the biggest wheel you can get in that hole is .750 and that's pretty small. I can't remember if the .875 bore will let you get a bigger wheel than .750 but I don't think so. With a .904 bore you can get an .815 wheel and that's a big deal.
So no matter how I slice it, the bigger lifter bore is always better. Comp and Pro Stock don't use 1 inch and bigger lifters because they want to spend extra money.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
