All manual transmission big blocks had steel cranks to the end of production so if that is a big block flywheel, it should be neutral balance.
Kevin
six bolt V8 flywheels have the same crank pattern, BB or SB so you can swap then around. No guarantee what that flywheel came off of or what BB he's going to run.
