Looks like it's going to need a trip to the machine shop anyway so maybe they could check balance?
I've seen non-factory balance jobs that consisted of a bunch of small holes drilled. Not seeing it here though.
As far as balance being an issue, until you know what you are going to run that can't be answered but generally the shop should be able to rebalance as needed.
