Re: 440 struggles past 4,000 rpm
[Re: Torquemonster440]
#2671116
06/28/19 12:39 PM
06/28/19 12:39 PM
Posts: 5,162 CT
GTX MATT
CT
I have the same carb, mine did not come with any restrictions on the IABs on the primary side. Square jetted at 78 out of the box it pinned my wideband at 10:1 (lowest it reads) at WOT. If you've got more jet I would suspect you are way rich at WOT if yours is of a similar vintage to mine and has the same calibrations. 74s or 75s square was a much closer starting point for me with the stock passage calibrations, still way rich everywhere except WOT though.
I would go to 78 square and see what that gets you. With 78 square this carb will cruise with an AFR of less than 12.0. What is you current jetting? If you are at 86/82 I'd suspect you could be on the verge of a rich missfire.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
Entire Thread
Torquemonster440
06/27/19 07:29 PM
pittsburghracer
06/27/19 07:55 PM
fast68plymouth
06/27/19 08:12 PM
Torquemonster440
06/27/19 08:45 PM
Cab_Burge
06/27/19 09:15 PM
68LAR
06/27/19 10:26 PM
Torquemonster440
06/28/19 12:04 AM
krautrock
06/28/19 12:57 AM
lewtot184
06/28/19 02:14 AM
Torquemonster440
06/28/19 02:01 PM
lewtot184
06/28/19 03:42 PM
Torquemonster440
06/30/19 06:29 PM
fast68plymouth
06/30/19 06:51 PM
Torquemonster440
06/30/19 08:50 PM
fast68plymouth
06/30/19 09:31 PM
Torquemonster440
06/30/19 10:04 PM
krautrock
06/30/19 10:54 PM
Torquemonster440
07/01/19 12:57 AM
GTX MATT
07/01/19 04:26 PM
lewtot184
07/01/19 06:15 PM
fast68plymouth
06/27/19 10:18 PM
lewtot184
06/30/19 08:32 PM
Torquemonster440
07/03/19 04:17 PM
Torquemonster440
07/28/20 01:36 PM
moparx
07/28/20 05:10 PM
Torquemonster440
06/27/19 08:23 PM
RapidRobert
06/28/19 11:44 AM
ChrgrCuda
06/28/19 12:18 PM
Torquemonster440
06/28/19 01:55 PM
Torquemonster440
06/28/19 12:19 PM
GTX MATT
06/28/19 01:17 PM
Torquemonster440
06/28/19 01:58 PM
GTX MATT
06/28/19 02:10 PM
Torquemonster440
06/28/19 02:37 PM
krautrock
06/28/19 03:56 PM
Torquemonster440
06/28/19 04:04 PM
GTX MATT
06/28/19 04:39 PM
ChrgrCuda
06/28/19 05:16 PM
lewtot184
06/28/19 05:21 PM
fast68plymouth
06/28/19 05:41 PM
Torquemonster440
06/28/19 07:59 PM
fast68plymouth
06/28/19 08:18 PM
madscientist
06/28/19 09:18 PM
sgcuda
06/28/19 10:26 PM
Torquemonster440
06/28/19 11:02 PM
fast68plymouth
06/28/19 11:07 PM
viperblue72
06/29/19 12:13 AM
Brian Hafliger
06/29/19 04:09 AM
Torquemonster440
06/29/19 09:01 PM
fast68plymouth
06/29/19 11:17 PM
Torquemonster440
06/29/19 11:43 PM
sgcuda
06/30/19 01:16 AM
MR_P_BODY
06/28/19 08:15 PM
TonyS451
06/28/19 01:19 PM
cgall
06/28/19 01:38 PM
Torquemonster440
06/28/19 02:00 PM
Exit1965
06/28/19 08:49 PM
johnnmo
06/28/19 09:03 PM
oldiron
06/28/19 01:36 PM
MoonshineMattK
06/28/19 03:53 PM
