Right, I used an E-3840 on a six pack setup a few years back. The taller element doesn't bolt into one of these air grabber setups though since the air cleaner studs will be too short to reach the top. I'm sure that can be solved of course. If the reproduction one isn't available then I suppose I'll end up using the K&N one.
