Why did you rebuild this trans - what was going on then?
Today -
Good reverse? What is the pressure in reverse?
What is the front servo release pressure doing in 2nd and when you get third?
What type of governor weight did you first take out - what was it made of? Not the valve, the weight.
Did you remove the overdrive piston retainer when you rebuilt the trans?
