One thing to remember is that synthetic oils prevent wear. Which means it will deter wear on surfaces that require break in. I worked for Mobil for 18 years. It was never recommended for break in purposes. I would run a regular high quality oil with zinc additive for first 500 miles or so. Maybe even for follow up oil change, before I would switch over to synthetic oil.
