At some point, the factory started adding a big weight to the back of the tail shaft. I think there was one on an 82 Cordoba I used to own. I always assumed the weight was to eliminate some unwanted harmonics. It would be interesting to see what would happen if you bolted one of those onto the tail shaft.
