Thanks. Here is an installed picture.
Hey Andy
Your water neck adapter is really good looking and aims the sensor in a way that the wiring would be real clean. On mine I have two senders in the water pump where you have blue anodized plugs- one for the autometer in my dash and one for the holley ecu. Is there any reason you didn’t use these? Mine read pretty dead on together and the factory sender was already using the outboard port on my donor 400 motor.
It’s funny- while I already had an innovate wideband and autometer water temp installed I was about to put in a vacuum gauge too- duh! MAP sensor is the same thing once I learned to read kpa! I do enjoy the redundant gauges though since the 3.5” screen is too small to watch much and I have it inside my glovebox door.
The sniper & hyperspark has been awesome so far- best $ I spent after the 512 stroker kit. Thanks for all your time on the different forums we’re on!
