Originally Posted by Get-X
Originally Posted by madscientist
CSK nailed it. Stop screwing around and call Mike. You'll be glad you did. I can't see the pictures, but unless the sweep is .040 or a bit less, you need to fix the geometry. Centering the sweep if it's .080 or more wide doesn't mean a thing.
Who's "screwing around"?? I spoke with Mike over a week ago and we had a very long discussion about this and lots of other things. He's a great guy and I really appreciated his time. That being said, I'll mock things up and look at them myself before I make any decisions. The scrub was .037 wide, .123 from the ex. side of the valve to .183 from the int. side on a .343 o.d. valve.
Misread your post then. I couldn't see the pictures. Maybe if I had my response would have been different. If the sweep is that narrow, run it. Being centered doesn't mean a thing.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
