Originally Posted by 68DART360
thanks for the constructive feedback. just what I was looking for jackass
got mirror?
Anything that uses a tap to connect to your factory wiring ought to have been clue number two for you.
Your probably the kind of genius that cuts the factory connector off the radio harness and uses wire nuts to attach some POS aftermarket radio in too.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
