Originally Posted by Supercuda
Had the spring for the flapper valve in my exhaust manifold break and the valve wouldn't open. It cause all sorts of hot engine issues that took me forever to sort out.
If you have headers, probably not the issue, if you have manifolds make sure that valve is working and will open.
That’s something I wouldn’t have thought of.
Valve was removed
