Originally Posted by RapidRobert
It might be the Hayden #2765 that is 2.67" long. EDIT & the cooling psi holding I was thinking of a potential slightly increasing head gasket leak. (& it may be as simple as the rad). I would want it at 185 or above with a confirmed accurate gauge.
Thanks I will check it out
