Had the spring for the flapper valve in my exhaust manifold break and the valve wouldn't open. It cause all sorts of hot engine issues that took me forever to sort out.
If you have headers, probably not the issue, if you have manifolds make sure that valve is working and will open.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
