T&D makes the best shaft rocker for that application but they are expensive. Jesel rockers are even better but would require machine shop work. I don't think I'd spend the money for Jesel rocker arms until 0.800 lift. You are under 0.600 lift which means that most any rocker arm will work. The Mancini rocker arms would work okay with that cam and save you a bunch of money.
