If you run 14’s you can still have some sidewall. On my ‘67 Barracuda I’m running 155R14 which clear my fenderwell headers but I have to have the torsions cranked up for ground clearance. It’s fun to try to check stock on a tire with no aspect ratio, which is an 82 series when it’s omited from the size, because they tell you that’s not enough digits.
1967 Barracuda Formula S FB 383/727
1967 Chevy C10 Short Stepper LS1/TKO 600/7675 Precision
1979 Ford F150 LWB 300 / 4 speed
1996 Toyota Land Cruiser
2024 Ford Bronco Badlands Sasquatch
2022 Kawasaki Z900RS
