Another trick is if the tire is catching the front tip of the fender,pull in the tip by the brace that it connects onto the front frame rail. You may have to elongate the hole in the brace at the fender to bring it in some more.
Tire will clear when turning.
Did that on 68 Dart GT 73 disc brake 15x6" Cragar SS .
Hope this helps
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
