I thought I would try the good aluminum ones. Made about a 80 ft pass and got towed to the pits after launching the Challenger. Should of just left the original strap type on that never ever failed for years and years. Listen the all the guys and pick what they have had success with. It is a pain to try to get those bolts out of the yoke after being sheared off and next to impossible at the track without a lot of help. Also some one said about using the solid U joint that is a good choice.
1971 HEMI E BODY REGISTRY
