This is a Dana I purchased directly from Strange years ago. It has the SOLID 1350 u-joints. I just had both front and rear 1350's replaced since they are about 15 years old with almost 1000 or so flawless passes. I think you talked me out of using the Girdle type .
Where can I get a suitable replacement for the U bolt type I have other than calling Strange?
Thanks mIke
