Stock stuff will work ok for valves, keepers, and retainers, just no thick rotating retainers. Springs should be what cam company recommends, or something similar. You also need to check retainer to guide clearance. Whoever did the heads is at fault no question, but doubt they admit it as you are the final quality control person.
