And in my opinion your cam, lifters, pushrods, rockers. valves, and keepers are all junk now. You will also need new springs and retainers that are for whatever cam you use. Did you tell whoever did the valve job what cam you had. No excuse for this if you did...
Yes. Everything was supposed to have been spec’d out for this cam.
What springs/retainers/pushrods/valves/etc should I go with?
