Calibrating the carbs the same as Edelbrock did for dual carb use should have been your starting point when you put them on the engine. I'm not so sure that a calibration kit will have what you need. I'd think you would need to order the jets and metering rods specifically for that conversion. Once you have the carbs converted to the dual quad setup then you can use the calibration kits to tune them to your engine.
