What gears? Was the converter built for a stroker or for the 440?
Unless it was built with 600+ ft of torque in mind, I guarantee you it will flash much higher than 3,000-3,500. These torque monsters absolutely require a converter made just for them.
Before you stick it in, I would suggest that you find out all you can about who built the converter and to what spec. I have had my share of struggles getting a good converter for my street/strip strokers.
In case you need to make changes, it is much cheaper and easier to do it now. Lenny @ Ultimate finally got me a really good street/strip converter after several misses from other converter builders including PTC.
