I am going to add foam to my tank........a 22 gallon aluminum sumped tank , and am wondering if it is possible to use any adhesive to hold the foam blocks in place.
The tank has a sending unit and I would like to avoid the foam blocks moving around and fouling / impeding the float.
I will be running E-85 and the foam is supposed to be O.K. with that.
I was wondering if some kind of silicone might work here.
That or maybe using a length of wire and " pinning " the blocks together.
Anyone have any experience in this area ?
Thanks in advance.
