I never used the pump alignment tool. I just put the loosely assembled pump into the empty trans case backwards without the o ring, started a bolt to keep it from rotating in the case then torqued the pump bolts.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
