Well said up
Another important consideration is the skill level of the installer.
You can look a little farther outside the box if the installer is good at tuning and working through other possible fitment issues that might arise(needs different springs, pushrods, etc).
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
