Me thinks the 40 spline axles gun drill lightweight option are a better choice for both rear ends
this is what I was told as well . And I can tell you first-hand a 40 spline with a big gun drill. Was lighter than my 31-spline that wasn't drilled
OK since I'm chasing light 9" with aluminum center section and gun drilled 40 spline? Do they make gun drilled 35 spline?
Strange charges around $140.00 a pair to drill 35 spline axles when you order them.
Mark Williams will also drill 35 spline axles but I'm not sure what they charge
Gus
