I could probably get some aluminum cut up and have it welded.....baffles would be good and I could put the fittings where I want them.
I'll price materials and a sending unit.
How thick would you recommend ?
.090 or so should be O.K. I think.
Did you set yours in the diamond plate box , or is it made of .125 diamond ?
