Originally Posted By tubtar
Originally Posted By MR_P_BODY
I would guess you dont weld.. a fuel tank is
pretty easy to build and you can make it fit
your needs.. this is one I built for my
Rampage.. its 18 gal with a sump.. I use a
external pump since I changed over to EFI
after I built the tank.. it has a sending
unit and a few lines on it
wave
I don't weld aluminum , and have the pics to prove it.
Did you bother with foam in that one , Mike ?
I like the changing fittings approach , and will definitely keep that in mind.
That is the most likely way this is going to play out.
No I didnt use foam.. I put 2 baffles in it for slosh
wave
