I like poly both sides or a solid/poly combo with a strap either way for insurance. I figure stock-type rubber will deteriorate/beat-out quicker while poly will offer longer life and less movement while still provide some dampening. Even with a solid/poly driver's side mount, it seems like OEM rubber will move/compress under load quite a bit.
